xQueueSendToBack
queue.h
1 BaseType_t xQueueSendToBack(2 QueueHandle_t xQueue,3 const void * pvItemToQueue,4 TickType_t xTicksToWait5 );
This is a macro that calls xQueueGenericSend(). It is equivalent to xQueueSend().
Post an item to the back of a queue. The item is queued by copy, not by reference. This function must not be called from an interrupt service routine. See xQueueSendToBackFromISR () for an alternative which may be used in an ISR.
xQueue
The handle to the queue on which the item is to be posted.
pvItemToQueue
A pointer to the item that is to be placed on the queue. The size of the items the queue will hold was defined when the queue was created, so this many bytes will be copied from pvItemToQueue into the queue storage area.
xTicksToWait
The maximum amount of time the task should block waiting for space to become available on the queue, should it already be full. The call will return immediately if this is set to 0. The time is defined in tick periods so the constant portTICK_PERIOD_MS should be used to convert to real time if this is required. If INCLUDE_vTaskSuspend is set to '1' then specifying the block time as portMAX_DELAY will cause the task to block indefinitely (without a timeout).
pdPASS if the item was successfully posted, otherwise errQUEUE_FULL.
1struct AMessage2{3 char ucMessageID;4 char ucData[ 20 ];5} xMessage;67unsigned long ulVar = 10UL;89void vATask( void *pvParameters )10{11QueueHandle_t xQueue1, xQueue2;12struct AMessage *pxMessage;1314 /* Create a queue capable of containing 10 unsigned long values. */15 xQueue1 = xQueueCreate( 10, sizeof( unsigned long ) );1617 /* Create a queue capable of containing 10 pointers to AMessage18 structures. These should be passed by pointer as they contain a lot of19 data. */20 xQueue2 = xQueueCreate( 10, sizeof( struct AMessage * ) );2122 /* ... */2324 if( xQueue1 != 0 )25 {26 /* Send an unsigned long. Wait for 10 ticks for space to become27 available if necessary. */28 if( xQueueSendToBack( xQueue1,29 ( void * ) &ulVar,30 ( TickType_t ) 10 ) != pdPASS )31 {32 /* Failed to post the message, even after 10 ticks. */33 }34 }3536 if( xQueue2 != 0 )37 {38 /* Send a pointer to a struct AMessage object. Don't block if the39 queue is already full. */40 pxMessage = & xMessage;41 xQueueSendToBack( xQueue2, ( void * ) &pxMessage, ( TickType_t ) 0 );42 }4344 /* ... Rest of task code. */45}
