xStreamBufferResetFromISR()
stream_buffer.h
1BaseType_t xStreamBufferResetFromISR( StreamBufferHandle_t xStreamBuffer );
An interrupt safe version of the xStreamBufferReset() API function.
Resets a stream buffer to its initial, empty, state. Any data that was in the stream buffer is discarded. A stream buffer can only be reset if there are no tasks blocked waiting to either send to or receive from the stream buffer.
Use
xStreamBuffer
The handle of the stream buffer to reset.
- If the stream buffer is reset then pdPASS is returned.
- If there was a task blocked waiting to send to or read from the stream buffer then the stream buffer will not be reset and pdFAIL is returned.
