Updated May 2025
vSemaphoreCreateBinary
[Semaphores]
semphr.h
1vSemaphoreCreateBinary( SemaphoreHandle_t xSemaphore )
NOTE: The
vSemaphoreCreateBinary()
macro remains in the source code to ensure backward compatibility, but it should not be used in new designs. Use the xSemaphoreCreateBinary() function instead.
Also, in many cases, it is faster and more memory efficient to use a direct to task notification in place of a binary semaphore.
Macro that creates a semaphore by using the existing queue mechanism. The queue length is 1 as this is a binary semaphore. The data size is 0 as we don't want to actually store any data - we just want to know if the queue is empty or full.
A binary semaphore need not be given back once obtained, so task synchronisation can be implemented by one task/interrupt continuously 'giving' the semaphore while another continuously 'takes' the semaphore. This is demonstrated by the sample code on the xSemaphoreGiveFromISR() documentation page.
Both mutex and binary semaphores are assigned to variables of type
SemaphoreHandle_t
and can be used in any API function that takes a parameter of this type.
  • xSemaphore
    Handle to the created semaphore. Should be of type
    SemaphoreHandle\_t
1 SemaphoreHandle_t xSemaphore;
2
3 void vATask( void * pvParameters )
4 {
5 // Semaphore cannot be used before a call to vSemaphoreCreateBinary ().
6 // This is a macro so pass the variable in directly.
7 vSemaphoreCreateBinary( xSemaphore );
8
9 if( xSemaphore != NULL )
10 {
11 // The semaphore was created successfully.
12 // The semaphore can now be used.
13 }
14 }
