Adding the TCP/IP Source Files to an RTOS Project
Part of the FreeRTOS-Plus-TCP Networking Tutorial
FreeRTOS-Plus-TCP is an open source TCP/IP stack and as such is supplied as source files that are intended to be built as part of your RTOS application.
It is best to start with a standard FreeRTOS application (without the TCP/IP stack) that is known to be working correctly, then add in the TCP/IP source files. It is recommended to use the heap_4 or heap_5 memory allocator. You can also use heap_3 if you are sure that the heap implementation provided by the standard library handles fragmentation. When you are sure the standard RTOS application is configured and executing correctly, do the following steps:
  1. Add the following core FreeRTOS-Plus-TCP source files into your project:
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_ARP.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_BitConfig.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_DHCP.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_DHCPv6.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS_Plus_TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_DNS.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_DNS_Cache.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_DNS_Callback.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_DNS_Networking.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_DNS_Parser.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_ICMP.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IP.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IP_Timers.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IP_Utils.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IPv4.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IPv4_Sockets.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IPv4_Utils.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IPv6.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IPv6_Sockets.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_IPv6_Utils.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_ND.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_RA.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_Routing.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS_Plus_TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_Sockets.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_StreamBuffer.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_IP.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_IP_IPV4.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_IP_IPV6.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_Reception.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_State_Handling.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_State_Handling_IPV4.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_State_Handling_IPV6.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_Transmission.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_Transmission_IPV4.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_Transmission_IPV6.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_Utils.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_Utils_IPV4.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_Utils_IPV6.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_TCP_WIN.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_Tiny_TCP.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_UDP_IP.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_UDP_IPv4.c
    • FreeRTOS/FreeRTOS-Plus/FreeRTOS-Plus-TCP/Source/FreeRTOS-Plus-TCP/source/FreeRTOS_UDP_IPv6.c
  2. Add the driver for your network interface (the MAC or Ethernet driver) into your project. Source files that implement network drivers are called NetworkInterface.c and are located in:
    FreeRTOS-Plus/FreeRTOS_Plus_TCP/source/portable/NetworkInterface/<microcontroller>/
    , where
    <microcontroller>
    is the family of microcontroller on which FreeRTOS-Plus-TCP will run. Instructions are provided for creating network drivers for other chips.
  3. Add the common PHY handling implementation to the project if the network interface used is one among those listed here-
    ATSAME5x
    DriverSAM
    STM32Fxx
    STM32Hxx
    TM4C
    . Source files are located in
    FreeRTOS/FreeRTOS-Plus/Source/FreeRTOS-Plus-TCP/source/portable/NetworkInterface/Common
  4. Add your chosen network buffer allocation scheme to your project. The source files that implement buffer allocation schemes are located in:
    FreeRTOS-Plus/FreeRTOS_Plus_TCP/source/portable/BufferManagement/
    . At this time
    BufferAllocation_2.c
    is recommended for simplicity because it obtains its RAM from the FreeRTOS heap.
  5. Add the following core TCP/IP directories into your compiler's include path:
    • FreeRTOS-Plus/FreeRTOS_Plus_TCP/source/include
    • FreeRTOS-Plus/FreeRTOS_Plus_TCP/source/portable/Compiler/<compiler>
      (where
      <compiler>
      is the compiler in use).
    • FreeRTOS-Plus/Source/FreeRTOS-Plus-TCP/source/portable/NetworkInterface/include
      (if the network interface used is one among those listed here -
      ATSAME5x
      DriverSAM
      STM32Fxx
      STM32Hxx
      TM4C
    • Any directories required to locate your chip specific driver header files.
  6. Add a
    FreeRTOSIPConfig.h
    header file to your project, and ensure the constants it contains are configured appropriately for your application. You can use a configuration file provided in an example project as a starting point.
    FreeRTOSIPConfig.h
    tailors the core TCP/IP stack for your application. It is application specific, not TCP/IP stack specific, and should therefore be located in an application directory rather than a FreeRTOS-Plus-TCP directory.
Back to the RTOS TCP networking tutorial index
