ulApplicationGetNextSequenceNumber()
FreeRTOS_sockets.h
1uint32_t ulApplicationGetNextSequenceNumber( uint32_t ulSourceAddress,
2 uint16_t usSourcePort,
3 uint32_t ulDestinationAddress,
4 uint16_t usDestinationPort );
ulApplicationGetNextSequenceNumber is an application defined hook (or callback) function that is called by the FreeRTOS-Plus-TCP stack to get a difficult to predict sequence number for the 4-value address tuple for a TCP connection.
Callback functions are implemented by the application writer, but called by the TCP/IP stack. The prototype of the callback function must exactly match the prototype above (including the function name).
  • ulSourceAddress
    The IPv4 address of the device.
  • usSourcePort
    The port number of the device to which the TCP socket is bound.
  • ulDestinationAddress
    The IPv4 address of the peer.
  • usDestinationPort
    The port of the peer to which the TCP connection is being made.
Return value:
A 32-bit hard to predict number should be returned by this hook to be used as the initial sequence number for the TCP connection.
