FreeRTOS software timers
Configuring an application to use software timers
To make the FreeRTOS software timer API available in an application, simply:
  1. Add the FreeRTOS/Source/timers.c source file to your project, and
  2. Define the constants detailed in the table below in the applications FreeRTOSConfig.h header file.
Constants
  • configUSE_TIMERS
    Set to 1 to include timer functionality. The timer service task will be automatically created as the RTOS scheduler starts when configUSE_TIMERS is set to 1.
  • configTIMER_TASK_PRIORITY
    Sets the priority of the timer service task. Like all tasks, the timer service task can run at any priority between 0 and ( configMAX_PRIORITIES - 1 ).
    This value needs to be chosen carefully to meet the requirements of the application. For example, if the timer service task is made the highest priority task in the system, then commands sent to the timer service task (when a timer API function is called) and expired timers will both get processed immediately. Conversely, if the timer service task is given a low priority, then commands sent to the timer service task and expired timers will not be processed until the timer service task is the highest priority task that is able to run. It is worth noting here however, that timer expiry times are calculated relative to when a command is sent, and not relative to when a command is processed.
  • configTIMER_QUEUE_LENGTH
    This sets the maximum number of unprocessed commands that the timer command queue can hold at any one time. Reasons the timer command queue might fill up include:
    • Making multiple timer API function calls before the RTOS scheduler has been started, and therefore before the timer service task has been created.
    • Making multiple (interrupt safe) timer API function calls from an interrupt service routine (ISR).
    • Making multiple timer API function calls from a task that has a priority above that of the timer service task.
  • configTIMER_TASK_STACK_DEPTH
    Sets the size of the stack (in words, not bytes) allocated to the
    timer service task. Timer callback functions execute in the context of the timer service task. The stack requirement of the timer service task therefore depends on the stack requirements of the timer callback functions.
